Discuss Cast iron toilet waste pipe. Needs to be cut down? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I need to this cast iron pipe back as my new back to wall toilet won’t fit otherwise. Cutting it back i am going to lose the collar. So what fitting can I get for it I would like a flex as it will easier for me when installing the new toilet
Reply to Cast iron toilet waste pipe. Needs to be cut down? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
