Discuss central heating problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi to all.i have question about my central heating.for the second time when my boiler is heating hot water in cylinder and heating radiators he just finish like he got his themperatur but after i while when you notice that is cold in house you try to get boiler to heat radiators more but no answer from boiler.after that i notice that water in cylinder is too hot (not usualy hot)i have hot water for 3 days or more)and boiler goes on after 1.30 hour.and working normaly.when i use all water from cyilnder i heat again the thermostat is working ok on cylinder.but after 6 days this happend again boiler not working water too hot.what could be a problem is it dangeros?thank you.
Thanks for you answer.Do you mean that timer is faulty?enginer come today tested evrything and its all ok he say.all that he check controls thermostats all working he say that he dosn't know what could happend.(engineer who install the boiler).so do you meen that my timer control is not working ok or what?at the moment all is working ok,but for how long?
Thanks for you answer.Do you meen that timer control is faulty or what exsacly is a problem with control?engineer come today check everything but all is working ok now and he did not finde any faulty.so i dont know any more.
hi to all i have a new problem actually dont know is it a problem.i have ideal logic +15 condensing boiler.he make some noisy when starting.its like his normal sound but louder then usualy then for a few second like a vibrating sound and then he work normal.is that some problem or its just because its all cold or what?
ok quick update its like silent vibration heard twice for about 10 seconds and it apears 15 min after boiler starts.and then stops.should i be worried about to call a engeenier or its ok?because is silent you can hear it if you are next to him.
about my first question when you saic its the control issue.i heat the water in cylinder yesterday for about 1 hour.today evarything was ok i was thinking i will turn on again to heat water for 1 hour.but thenni noticed that water in cylnder is hot another plumber come an sais that 3 port motorised valve is stuck in middle position so i am getting hot water when heating is on?is that possible he will change it but how we overy change the thermostatic because a mistake i don't want to do another one by mistake.another opinion please?Thank you
Reply to central heating problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
