Discuss Central Heating system design in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MikeJB
Can all rediators in a system be controlled by temperature valves? What happens if all rooms are warm enough and therefore all valves closed?
The rad in the room/area with room stat should not have one. A system bypass as well or lockshields on bathroom rad/towel rail.
They can but not recommend as normally if a bathroom rad has a trv it gets covered with a towel so doesn't come on much etc
if you fitted the Honeywell evohome system, each radiator is individually controlled
Reply to Central Heating system design in the Plumbing Jobs | The Job-board area at PlumbersForums.net
