Discuss Ceramic cartridge spindle wobbles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there.
I'm a home DIYer with a question (please excuse if my terminology is incorrect).
A tap I have has a wobbly handwheel. On removing the handwheel I found it's the spindle of the cartridge that's wobbling. In off or fully on postions the spindle doesnt wobble, it only wobbles when the tap is around half way on. It is also very stiff to fully close. What's my best way of fixing this?
Thanks for any help or suggestions.
Good point. Note to self, "Be specific".
The top disc is driven by a 'converter' at the bottom of the tap spindle. Its this that often wears and the part where it connects in the top disc. Part of the wobble will also be worn spindle o-rings
Reply to Ceramic cartridge spindle wobbles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
