Discuss Ceramic cartridges lifespan?? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
macka09
Hi folks.
I replaced a cartridge about 18months ago for somebody and it’s failed again. Are they really only designed to last a couple of years?
It’s in a catering kitchen so gets lots of use but I’m surprised it’s gone so quick.
Is it the hots ?
Should last many years.
The hot cartridge in my own kitchen tap failed after about 35 years because the brass body had developed a crack (probably due to corrosion / dezincification) but the ceramic discs were still in as-new condition.
I think that it's critical that the cartridge body is the correct length. Slightly too long and when it's screwed into the fitting the sealing ring will push the discs together with too much force. When new they often have some silicone on them so will work fine (maybe feel a bit stiff) but the discs will wear/bind prematurely.
Unfortunately there’s no markings on the tap or cartridges so I had to go with the closest possible. The first time I changed it was last June and it’s failed already.
I did ask the merchant what the warranty period was and his reply was “ I don’t think they have a warranty”.
Okay, if the cause of failure was incorrect length. You need to decide if it failed because the cartridge body is (a) too short or (b) too long. If it's (a) the tap will be dripping will operate freely and be otherwise okay. If (b) there will be significant resistance when you try to open/close the tap. If you inspect it the thin sections of brass next to the slots may have been distorted.
If you remove the outer seal O'ring and then screw the cartridge in by hand you should be able to feel the point when the compression washer that forms the inner seal touches down and you can see how much it will be compressed by gauging the gap left where you removed the O'ring.
Trouble with this sort of fiddling around is that it is time-consuming and can end up costing more than replacing the tap with a branded one that you can get the correct spares for first time.
Thanks for the advice it’s much appreciated.
The replacement cartridge is identical in length which is why I was surprised the cartridge only lasted 18mths.
Oh, okay, I misunderstood what you meant by 'closest possible'. How long did the previous cartridge last?
Take a careful look at the failed cartridge to see if it gives any clues as to why it failed. For example, if the tap is operated by a long lever maybe it's been subjected to excessive torque damaging the end-stops.
The last cartridge was only 18 months.
I can see gaps on the discs though.
I find very hot water wears them faster also think of the use it’s a lot more than a domestic house
I did say to the lady it could be due to the high usage. Plus, like the chap said above, if they’re slamming them shut with the lever handles that probably doesn’t help with the longevity.
We look after a number of restaurants from small to some that can do over 300 covers.
Most common repair we do in kitchens is dripping taps .
All of above lots of use - hard water and nearly always hot taps.
Over years we have replaced taps with Bristan so can always do a first time repair.
Reply to Ceramic cartridges lifespan?? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
