Discuss Chasing CH pipes using speedfit in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I'm chasing some walls and using speedfit for pipes to the radiators.
I'll be using conduit and want to transition to copper ends which will connect to the rads. Can I bury the speedfit fittings (elbows etc)?
What are the options for pipe exiting the wall and connecting to the rads? Do I chase the walls in-line with the TRV's at each end?
Thanks!
Oh! Figured it out!
Pushfit stems.
One wall chase | pipes come out in middle behind radiator | 90 deg elbows splaying out pipe to each TRV
An example in this vid:
Reply to Chasing CH pipes using speedfit in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
