Discuss Chasing rad pipes into walls in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Good evening all. I have a client who has just bought a pretty big house. Lots or rads. Any way, the bottom floor is concrete and all pipes drop down walls and along skirtings. She hates it. She wants them hidden. I said we could batten the skirting out and run behind there. She doesn't like that option. She wants them buried in the walls. All brick by the way. Messy I told her.
My question is really, would you guys do this? Is there a better way? I think it will be about half a day to do each rad as ceilings are like 3 metres and then another 5 metre runs to big rads. I wouldn't like to be the chippy who has to put those skirtings back as all walls wobbly so no more nails won't do the trick. Squeeky bum time
if shes willing to pay you dont see a problem as long as the pipes are protected
Tracking the floors is a good option.
Just mark out the runs and get the client to do the tracking or builder if he's on site.
Not as much mess tracking the floors and its better because the pipe can terminate at the rad valve location.
I'll do that if the customer wants it. Usually hire a wall chaser....creates a lot of dust even with extractor! If it's too much for me I just sub the wall prep out to a builder.(Then it's an easy plumbing job.) Pressure test then denso tape & mark/map where pipes are....
Parquet flooring downstairs so not an option.
How do you run pipes, pressure test and wrap in denso? Or do you just.cover the front?
use plastic coated pipe, always pressure test before sealing back in wall, buy a wall chaser as part of the job cost only a £100 or so for one from screwfix.
The chase needs to be deep enough so the pipes are clipped away from the masonry. Then I pressure test. Finally wrap in denso or use the plastic coated as suggested above
I think I'd be worried about chasing the walls horizontally for lengths like 5 metres. Could be weakening them at the point of greatest load. Vertical chases should be OK.
Reply to Chasing rad pipes into walls in the Plumbing Jobs | The Job-board area at PlumbersForums.net
