Discuss Cheap glow worm betcom 4 30c in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
Advice, I'm wondering about the glow worm combi that has the mechanical time clock displayed on the front panel, can this be disconnected? As I'll be installing it in the loft and using the exciting room stat/ programmer.
Not much experience in glow worms and I don't do electrics.
Yes, you set the built in clock to always on and connect any external control via the thermostat connections.
Section 10
https://www.heatingsparesltd.com/do...acom_24_And_30_Installation_And_Servicing.pdf
Boiler in a loft my pet hate ! and a cheap one at that not a wise move bud you will lose so much heat through the casing and be heating a uninhabited space factor in wind chill freezing temperatures problems with condense I would not put it there. You can just leave mechanical timer on constant and use a rf programmable thermostat but as I said try a find a different location if possible. Kop
It's the only place that's suitable one bedroom bungalow so tight for same plus it needs to be finished in a day. I'll insulated th pipework to death. Thanks for your advice and tips!
Reply to Cheap glow worm betcom 4 30c in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am looking for some basic advice please My house is on two floors, approx 240m2 and a spacious loft with good headroom and access. Glow Worm...
So I've got a Glow Worm back boiler fronted by a gas fire, at least 15 years old probably a lot more. The water heating makes a row as there is a...
Hi, looking for some advice/pointing in the right direction. We’ve got a glow worm betacom 24c combi boiler, installed by the last owners. Doing...
2K
Hello all! Can I please have some professional opinion on our ongoing problems with our Glow-worm Fuelsaver mk11. Now I know the simplist answer...
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know...
