Discuss Checking a central heating pump? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Danv44444
Hi guys, I was reading a book and it said if a central heating pumps bearings have warn out, when you remove the big screw in the middle then water will pour out?
I was thinking every time I've removed the screw in the middle water has always poured out?
whats the best way to check a pump is working properly?
The book is wrong. What issue of the Beano is it?
You can hear/feel worn bearings. If you put your scrotum on the top surface and your tongue pops out of the top of your head then there're worn.
that is the secret scientific way don't be telling everyone
Remove end screw.
Jam big screwdriver in quickly and hold on tightly.
If you spin around quickly like a cartoon character then the pump is O.K
If you can stop the pump it's probably only a 15 -60
The water lubricates the bearings.
LOL at that
Pmsl - and don't forget the sudacream in case it's really worn
Reply to Checking a central heating pump? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
  • Article
The UK Government has today been told to do better when it comes to Heat Pumps and Hydrogen Boilers. A watchdog for spending has said that the...
Hi guys. A couple of things. 1 am I better fabricating bends in 14 mm copper for my ch or are 90 degree elbows fine, ref flow, friction ect. 2...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
Hi all, Just a quick question. I have a log burner and a gas boiler on a dual fuel system (Central heating and Hot Water) either can do both. The...
