Discuss Chrome pipe bending and filing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
whats the best and quickest method of filing off the chrome plating on chrome 15mm copper? And is chrome pipe bendable? Any method I need to adopt to bend it?
Doing a job next week fitting 10 new rads and the woman wants all rads to have chrome pipework coming up from floor.
Just a normal file will be ok
And yes any good quality chrome copper will be fine just take it slowly and do a test bend first
You reckon a dremel will be ok to use? Need it to be quicker than a file
Normally file it off in less than 30 seconds
You can use a grinder with a sanding disc if you want it sharpish
use a rasp, bahco do a handy one, fine file on one side and a coarse rasp on the reverse.
I'll see if I can grab one and have a bash at the weekend.. cheers Tolly
Some brands of chromed copper pipe are easier to file the chrome off than others. Use a new flat file, keeping it totally flat against the pipe.
Maybe best where possible to just use straight piece of chromed pipe and a soldered elbow, to save you having to do machine bends
If you do have to bend chromed pipe, - use some oil on the bender and pipe. Note that the manufacturer will not guarantee the pipe if you bend it.
I use a grinder with a metal blade. But tbh, as long as your back to bright copper, your sorted
Or tell the woman to buy some chrome pipe snap covers! ;)
They look as good as real chrome if fitted well and you can replace them to have it looking good as new in the future. At least, that's the spin I use to save me filing bloody chrome off pipes!
They don't do offset ones tho best
Definitely a file. I use one I got of me good Dad. It's about 30 years old. Problem is, I only have one on the van and when I want it I can never find it:p
I used to be like that, now I'm anal about keeping my van tidy. After every job I put things back where they need to be, even if I'm in a rush. Cos I know the moment I just chuck it in the back I'm spending half hour looking for it next time lol
It is a problem with files, unless you have a handle on them - and a brightly coloured one, or they will blend in with other tools or lie on their edge.
I have loads of times searched my tool box I thought thoroughly and decided I had lost my file, only to find it in the same tool box later. :)
Normally after you bought a new one :D
Thing that annoys me is putting tools down in a job, you go to get it and it ain't there.. you search for 10 mins every where and it's in the same damn spot you first looked at.. does my head in lol
Done that before a few times! That why I keep 2 of most tools, - if I can't find one spanner, I will probably find the second one and then stumble upon the first in a few days.
The work of a handyman and compressions.. lol I lowered it yesterday and changed the valves to straights and put a couple of offset bends
And I think I see cheap isolating valves on the pipes as they come out of floor? Absolutely hate them and definitely not for heating pipes
I agree with that Sir. Horrible things and more often than not useless and leak !
I never use them on heating systems.
They seem to be on everything at the moment.
I totally stopped using them even on cold supplies to toilets etc. I only use the good quality full flow valves on hot & cold supplies and I never use valves on heating pipes unless lever or gate valves that are there for good reason.
Too many DIY or " I am a plumber" type people doing plumbing who have no idea really. The isolating valves just makes their job easy to stop water flowing
Same here. I can't see the point in fitting restrictive leaky valves everywhere.
In my opinion, if you're a decent Plumber, you don't need them anyway. More often than not you can manage to shut off or drain something whilst you fix can't you?
It drives me insane, going to repair something only to find you have to replace the leaky isolation valve as well LOL.
Same with those quarter turn pump valves and drain taps at the bottom of the heating system that fill with gunk and the washer rots onto the seating.
Rant over !
Rant over !
Cannot stand quarter turn pump valves, if I need to change a pump and I see those my heart sinks.. I know the minute I turn it, if it turns at all, it will leak and won't stop. So always just replace them with gate pump valves
Reply to Chrome pipe bending and filing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
