Discuss Circulations problems on a upland open vent system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
JAH HEATING
Turning into a bit of a ballache...
had everywhere roasting, couple of hours latter downstairs living room rad goes cold an a bedroom one..
had hose on drain offs, throttled lock shields right down on upstairs, trvs off on rads an at times it gets hot, then stops...
it has x400 in system to, any suggestions ?
Constanly venting a couple of rads to remove air
upland??
constantly venting could be pipework issue, pump sucking in air?
Not micro *****? Or plastic on walls is it? Pumping over due to blockage?
Altered pump speed?
Altered pump speed?
No mate, all 15 on 3 drops. 8 rads in total.
altered pump last night, late last need. Half nine to be precise.
it had a potterton suprima in, replaced it yesterday an had everything bouncing.
i drained down each leg, pretty cleanish to be honest.
filled up cold an let it run for a bit on each doff.
through some cleaner in, an got everywhere hot an was going to go back an flush it midweek.
I did one recently
I did one recently tank clean as some idiot drained down and rinsed all debris in to system
I'd go with partial block on the return pipe or just stubborn old fashioned air moving about.
If it's air, any suggestions ?
think I've got an old spirotech I could through in, can't go next to boiler. No room an it would look a joke.
That will get rid of the air but you still have the problem of the system dragging air in from somewhere.
you said you reconfigured the F/V, what about combining the feed and vent?
Reply to Circulations problems on a upland open vent system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
