Discuss Circulations problems on a upland open vent system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
JAH HEATING
Turning into a bit of a ballache...
had everywhere roasting, couple of hours latter downstairs living room rad goes cold an a bedroom one..
had hose on drain offs, throttled lock shields right down on upstairs, trvs off on rads an at times it gets hot, then stops...
it has x400 in system to, any suggestions ?
Constanly venting a couple of rads to remove air
upland??
constantly venting could be pipework issue, pump sucking in air?
Not micro *****? Or plastic on walls is it? Pumping over due to blockage?
Altered pump speed?
Altered pump speed?
No mate, all 15 on 3 drops. 8 rads in total.
altered pump last night, late last need. Half nine to be precise.
it had a potterton suprima in, replaced it yesterday an had everything bouncing.
i drained down each leg, pretty cleanish to be honest.
filled up cold an let it run for a bit on each doff.
through some cleaner in, an got everywhere hot an was going to go back an flush it midweek.
I did one recently
I did one recently tank clean as some idiot drained down and rinsed all debris in to system
I'd go with partial block on the return pipe or just stubborn old fashioned air moving about.
Reply to Circulations problems on a upland open vent system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. A new house regulation for a 2 zone heating system because it's bigger that 150sqm. I'm I right in saying zone 1 should be all of the...
2K
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
Hi everyone, I'm a (somewhat, I hope...) competent DIYer and just want to get some advice if my suspicion on a problem we're having is correct...
L
Im just wondering if anyone can give me some advice as had 2 plumbers round and still getting same issue. Ive recently loved into a new house and...
