Discuss Cistern Pan Hose Question in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have a pneumatic concealed cistern behind a removable vanity panel. I pulled the panel off to investigate a dull knocking noise when the cistern is coming to nearly full, I haven't ascertained what this might be as yet, I wondered if it was the cold water pipes knocking (as in water hammer) but this wasn't the case.
However, this is the first time I've had this vanity front off since living here for four years and I noticed the hose between the toilet and the pan is slightly on the wonk / angle and the connection to the pan looks like the attached photo.
This has been fine for over four years we've been here and it's been in place for ~13 years so I am not minded to mess with it but just wondered if this looks normal.
If it has been like that for so long and not leaking then don't touch it. The seals will have formed to this shape and won't take kindly to being disturbed
That was my thoughts... Is it common for these hoses to be installed on the wonk? In an ideal world it would be square / lined up surely.
That’s water hammer either the inlet / fill valve is bouncing / or there’s a pipe rattling
Thanks. The strange thing is, it doesn't happen all the time. Another flush right after and it's fine. It happens towards the end of the filling and I even have felt the copper pipe leading into the flexi hose and that is not seemingly vibrating.
Would change the fill valve
I will ask my plumber to that when he is here next... Presumably they aren't standard and it will be specific to my cistern?
Maybe a siamp but your plumber will be able to tell / sort it
Looks like a Grohe got in and took a picture.
More concerning though is it appears to also have dropped on side per the video. I'm surprised it was fixed with two screws and not with washers which presumably is the reason for it slipping on the left side. Again it's probably been like this for years so will let me plumber take a view on it. Disturbing it's position might lead to bigger problems but at the least an extra screw on the left might prevent it departing the wall and flooding.
Not sure who the plastic cistern is made by. Couldn't see any markings.
  • VIDEO-2024-01-19-10-22-55.mp4
    3.6 MB
Reply to Cistern Pan Hose Question in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
