T
The_Tonk
Does anyone have a Citroen relay van with a history of problems starting?
I have a 2007 2.2hdi model and recently it has been an bit of a pain when starting.
Not all the time and not always the same thing!
Some times the key fob does not work/several presses of the button to open door.
When key is turned engine turned over but will not start can sometimes take 3 attempts before it will start then all fine, can happen when hot or cold.
Other times it will start 1st time but not idle and just cut out.
Or start but not rev at all or seem to be in a limp mode.
Or it will start and drive fine.
Not sure if related but recently it has randomly started beebing at me with the door open light coming on while driving.
Pretty sure it must be an electric fault but just wondered if anyone else has had a similar problem.
Have only had van since October and spent a small fortune on it, fuel injectors, timing chain cover etc.
