Discuss Cleaning boiler heat exchanger - a handy hint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
Ian B
I have a good set of brushes and cleaning tools for boiler heat exchangers but recently came across one where none was small enough to get into the space.
To the rescue, a 5mm cable tie. The serrations help to get deposit off the fins, and the plastic is too soft to damage anything.
Job done.
Cheers for that, I have a large selection of "tools" for this but had not thought of cable ties. My wife does get a bit worried when I find something in "Poundland" or similar that would be just the thing for those tricky exchangers.
Perfect !
Junior hacksaw balade with one of the nibbly bits cut off and a few wraps of insulating tape on the other end to act as a handle...Slips lovely up a suprimas crack
Reply to Cleaning boiler heat exchanger - a handy hint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
we had a grant condensing boiler fitted last year, the lad works for a heating company and said would fit it. when he did he put the pipes all...
Hi everyone - Recently bought a house which is currently heated via FHW via an oil-fired boiler. Hot water is also provided by the boiler (via a...
1K
Hi All, I have the above mentioned boiler linked to a Nest Thermostat. The problem I have is when the boiler is set to No.5 which heats the water...
4K
  • Locked
Hi, Just wondering if anyone can offer some advice, I've got a combi boiler (Getting pretty old now I think its around 12+ years old) currently...
1K
A number of issues have been raised from a boiler replacement. Boiler not operating and with no pressure. Tile damage Sprawling pipe layout in...
5K
