Discuss Combi Boiler in a Bathroom? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PowerFlusher2
Just watched DIY SOS and saw that they renovated a bathroom which had a combi boiler on the wall? Never seen a combi boiler fitted on a bathroom wall before. Does it happen often?
It's not too common here but may be permissible, depending on MIs and electrical zoning.
Regs may have changed a little but a combi in a bathroom can be ok dependent on where it is positioned.
As a rough guide tho.
Zone 0. No Combi ;-)
Zone 1 & 2 in a purpose built cupboard only openable with a tool.
Zone 3. No restrictions
As an aside tho the circuit must be protected by a 30mA RCD.
never amazes me , who owned the flat ?
The same chap who ran the takeaway below. The staff lived there, I really should have a look next time i'm passiung to see if the flue is in the same place still, Bizre thing was it could have easily been put in the store room on the floor below with minimal work.
Never reported as assumed I would be back to rectify, it was only a couple of lengths of pipe and half a days work to sort it!
Zone 0 is in the bath or within a shower enclosure, above the bath without a shower facility fitted, is Zone 1.
A boiler, fully enclosed, accessible only with a tool and protected by a 30mA RCD is acceptable in Zone 1.
I stand to be corrected, any 17th edn. sparks got an opinion??
Reply to Combi Boiler in a Bathroom? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
My installation has been classed as Dangerous 'Do not use' by my boiler manufacturer. I have an Ideal Logic 30kw Combi boiler mounted as high as...
