Discuss Combi boiler. Running CH whilst DHW drained. in the USA area at PlumbersForums.net
Have a query regarding a morco combi boiler in a mobile home. It's set up with a link on the thermostat connections within the control panel and heat is controlled by Trv's. I'm planning on adding a hive thermostat to give me more control and intend to use the app. My question is, when the DHW is drained over the winter can I still run the CH via the app. We would use the mobile home a few times over the winter and it would be handy if we could turn the heating on via the app a few hours before hand. I would have to leave the boiler on but the hive app thermostat switched to off. Would any damaged be caused to the DHW side by running the heating. Thanks
which model of morco have you got
No preheat I think. As for frost protection when the boiler is switched to zero the frost protection kicks in below 6 degrees I think. So I'm assuming when the boiler is left on and held off by the stat the frost protection doesn't work. Probably add some frost protection through the hive stat. Was just worried that running the CH whilst HW drained would cause damage to the HW side. Does these boilers divert to a secondary heat exchanger for the HW? Had a look at a diagram online and I think that's the set up. Maybe that's standard on all combi's.
Hi, Scotty92,
I found your original post while researching for an answer to the very same question you asked!
I was wondering how you have got on with your situation, as you had some very good replies.
I have the same boiler, a Morco gb24 in my ABI Lodge and also would like to swap out the mechanical timer and install a Hive system to control the system via my iPhone, so I could warm the home up prior to arrival.
Would you spare me some time and reply with your comments?
Thanks!
Chris B.
Yes thru a secondary heat exchanger which wouldn’t be used as no water in domestic pipework so no flow from any tap to turn it on
Reply to Combi boiler. Running CH whilst DHW drained. in the USA area at PlumbersForums.net
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few...
I would like to ask for specific product recommendations (or examples of such) that: a) Fit a standard back plate b) Would work with an existing...
Deleted member 120897
