Discuss Combination Valve Installed Correctly? in the USA area at PlumbersForums.net
I have an unvented cylinder with a water combination valve before the inlet. It has been installed with the "balanced" cold water feed coming straight off the combination valve and not after it. Is this installed correctly? If not, what are the consequences of this connection? Many thanks!
yes looks fine to me
Thanks for your responses.
Does this arrangement mean I am getting the reduced 3 bar to both the cylinder and cold water feed?
I've found the following in the cylinder MI and thermostatic shower MI. What arrangement do I need? (Not sure if one MI trump's the other). Thanks again!
Most likely yes it is balanced
What about the unvented cylinder MI saying that the expansion valve on the combination value shouldn't be used for any other purpose and that a balanced supply should be taken off after the combination valve?
Is an expansion vessel required?
Sorry I'm a bit confused!
There's an internal bubble in the cylinder, but is
If there isn’t an internal bubble then there needs to be an external expansion vessel.
You need to be G3 qualified to work on these cylinders.
There's an air bubble in the cylinder, but is an expansion vessel required on the cold feed to my thermostatic shower after the combination valve? It's currently difficult to turn down the temperature in the shower and I wonder if it's an imbalance in pressure?
No, expansion is only needed when water is heated.
Why didn’t you mention the shower in the first place?
If it won’t go cold it is usually one of three things.
1. cold inlet filter blocked
2. cold non-return valve stuck
3. cartridge failed/needs servicing
Check them in that order.
thanks, I’ll take a look, although I have had this issue since the shower was originally installed if that sheds light on anything?Turning the temperature down is possible but with some force and the difficulty isn’t consistent on each turn. Increasing the temperature is always mouth and easy. Worth pointing out that the cylinder supplies hot water to a kitchen and two bathrooms while the cold outlet from the combination valve only supplies one of the bathrooms.
where is the cold non-return valve?
thanks again
Reply to Combination Valve Installed Correctly? in the USA area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
