Discuss Comfort height toilet flush pipe in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi guys
So a bit of a dilemma
Normal WC Unit height 766mm which is around the average mark.
quite alot of bogs lets say the flush pipe center from floor is 330-340ish.
However I have a comfort height Pan here and the center to the flush pipe from floor is 405MM
So we're looking 65-75mm higher than normal.
So as you've probably guessed the cistern flush pipe won't sit high enough to insert into the toilet, even with the cistern sitting flush to top of the unit.
Any ideas on a best solution other then changing the toilet
Regards
Or raise the cistern
Reply to Comfort height toilet flush pipe in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
L
Hi all, First post here so please be patient. We recently had our ensuite remodelled and were initially really happy with the result. However...
I wonder if anyone is able to help with advice on this. We have fitted a new toilet and 6 litre cistern .. it flushes .. but not as efficiently as...
2K
Hi there, I have a commercial customer who asked me a few months ago to investigate a toilet that kept blocking. They'd just had the blockage...
B
Hello, I've had unfortunate issues throughout my adult life and more so since switching to a largely plant based diet of blocking toilets...
I've got water trickling into the pan of a toilet. The cistern water level is nowhere near the overflow pipe, so I suspect there's a faulty seal...
