Discuss Comfort height toilet flush pipe in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi guys
So a bit of a dilemma
Normal WC Unit height 766mm which is around the average mark.
quite alot of bogs lets say the flush pipe center from floor is 330-340ish.
However I have a comfort height Pan here and the center to the flush pipe from floor is 405MM
So we're looking 65-75mm higher than normal.
So as you've probably guessed the cistern flush pipe won't sit high enough to insert into the toilet, even with the cistern sitting flush to top of the unit.
Any ideas on a best solution other then changing the toilet
Regards
Or raise the cistern
Reply to Comfort height toilet flush pipe in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
