Discuss commercial heat exchangers vs domestic affecting efficiency. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
Whyme
Just found this out recently that commercial boilers only slightly bigger than domestic in kw that have a bigger case/ heat exchanger etc are more efficient. apparently it because domestic boilers with there fit in cupboards design have to have a smaller heat exchanger thus have to have the co2 lower and o2 higher to burn slightly cooler so not to knacker the tiny heat ex. bigger less restrictive heat exchangers can have a better more efficient mix ie slightly less o2 ( without a cooler lean flame) thus burning the gas more efficiently and getting closer to that sweet spot...
Reply to commercial heat exchangers vs domestic affecting efficiency. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am contemplating of having 2 domestic boilers (35-40 kW each) for the communal heating (no hot water) of a 12-flat residential block that would...
2K
Hi, sorry to bother you all with this but I am really struggling to find a suitable combi-boiler replacement and a knowledgeable heating engineer...
1K
Hi guys, I was wondering if anyone was out there who could shed some light on commercial heating. If you can, thanks in advance. I’ve been a...
4K
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
T'other day, the subject of hydraulic separation came up again on this forum and I decided it would be interesting to look at the subject again...
8K
