- Messages
- 34,369
- Solutions
- 2
Discuss Complete central heating system setup - advice please in the USA area at PlumbersForums.net
very helpfulWrong
To go into a full explanation of pump positions relative to the boiler is pointless when anyone can search the forum or web and see the same thing explained at least every month in great detail - to which I'll only add that pump on return did make sense 3000 years ago, but since I have a customer who's 1980's or early 1990's Grundfos is now on the flow of its third boiler, I don't think it's now an advantage compared with the potential pitfalls. Good to mention it though, as otherwise the OP will (may) run into serious problems at some point down the line even though the pump and vent arrangement may not have a direct bearing on the current issues at hand.Wrong
Exactly. Seems foolhardy to install it first and understand the details after. But each to his own.Tbh wrong time to ask questions once it’s been installed
Feed and vent are in the wrong position in relation to pump placement hence my diagram/ picture it’s in positive pressure eg pumping over
Not sure I follow re pump. He's got the pump on the return, and the close coupling is correct IIUC. Surely the risk is negative pressure between the pump and cold feed with increased risk of air ingress (and cavitation at valves?).
pump is not above boiler at allI understand it as pump is on the return above the boiler and the vent and feed are on the flow in the airing cupboard eg left hand drawing
no, not fool hardy at all, so you dont setup a system after install? not very good practice, there a difference between installing a system and setting it up for best performance! NO air in system hasnt been since install. nothing wrong with pump on return makes no odds.Exactly. Seems foolhardy to install it first and understand the details after. But each to his own.
thats makes no sense atll all, its a simple setup up question and a process that any good plumber undertakes after a install, sounds like you just install it and walk away, not giving your customer a complete service then and getting the best from there system.Tbh wrong time to ask questions once it’s been installed
Reply to Complete central heating system setup - advice please in the USA area at PlumbersForums.net
