Discuss Completing a benchmark in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SWG Solutions
Just a quick one;
When filling out the benchmark when installing a boiler, when you use the manufacturers app does that mean you don’t have to fill the one in on the actual paper manual?
Also, when installing a gas hob I know you don’t have to fill in a benchmark but is it always best to complete a ‘declaration of works’ form?
Thanksssssss
No always need to do the benchmark
And yes also I would fill in one eg working pressures and load etc
Vaillant sent me a copy of the one I done online via email. I was wondering if they send it to the customer too? It seems pointless to fill it out online and in the manual.
The hob I recently connected didn’t come with a benchmark, when I checked online it says you don’t have to. When you say fill one in, do you mean that’s the info required on the declaration of works form?
How does a repair guy know the base line figures when he goes and services it 4 years later and the customer doesn't hand him anything etc
Also some manufacturers won't repair it without it filled in
I would fill out a service / llgsc sheet then least you can put all your info and base settings on it
My guess is that they would send the copy they emailed to me to the customer too?
Just a quick one;
Thanksssssss
The hob is notifyable to gas safe.
if you give vaillant or glowworm the customers email when registering they send it to them. i also think they mail it out. you can always print it out. but its a failsafe if you fill the book in
Always fill out the Benchmark. For hobs/cookers I fill out a maintenance sheet and just state new installation. That way you’ve documented your install and the figures.
Flueless hobs and cookers are not notifiable mate. @Harvest Fields
Stu.
Stu.
It’s a voluntary process mate through a declaration of work. But I do it all the time. I know they are not notifiable to building control.
Reply to Completing a benchmark in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
