Discuss compression fittings on chrome pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When I was training, my mentor told me that in order to get a proper seal with chrome pipe and compression fittings, it was necessary to remove the chrome plating at the end, in order to get the olive to "stick". What does everyone else do? I have always done this but have now been told that it is not necessary.
Not necessary on chrome, in fact your making it worse. Just a little paste will do.
when soldering you will need to remove the chrome.
Need to file ir for push fit as the chrome is harder than the grabring in the fitting so it cant bite and just pops off.
Some chrome pipe can be soldered some can't. Better to just fime it off.
Nit necessary for compression fittings
Reply to compression fittings on chrome pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
Hi all, I'm in the process of fitting my freestanding bath. The supplied waste chrome pipe that runs into the floor is an unusual diameter -...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
