Discuss Concealed cistern fill valve. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
Has anyone got an idea what make concealed cistern this maybe? I need a new full valve for it. Thanks
Just looks like a stnd inlet valve maybe a Thomas Dudley fill valve might fit etc
Edit it’s a cera/ siamp frame
Yes and yes you can pull it out and tighten the flex on the just nip up the retaining nut
1/2 by 3/8 probably
Yes ball valve end should be 1/2
Thanks what's happening with it is. Flush the toilet. It flushes water stops flowing in to bowl. It then starts flowing in to bowl as the fill valve isn't shutting off. It will stop for some reason if pressure the small button on the flush plate. Strange!
So anyone know what the blue but is sticking out if the thread? Worried this would effect the Flexi sealing?
It pushes in further / cut it off it’s a strainer / flow limiter and yes iso valve normally ok
Any idea why it just fills and won't stop. I presume this is a washer or problem with the arm. But then why it stops when the small flush button is pushed. Unless it's jolting it to shut it off.
Reply to Concealed cistern fill valve. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days...
