Discuss Concealed shower advive please. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
We had a plumber come to fit our concealed shower. He plumbed it in, then we fit the plasterboard and tiles. However he soon realised that he had set the shower valve body too far back into the wall so that he physically could not fit the valve handles onto the spindles because they do not protude the wall far enough. Is there anything we can do about that or do we need to break into the wall again to move the valve body??
Realistically, you may have a 25% chance of not having to open the wall up..
All good, plumbers insurance should pay for the repairs and he / she will cover their excess at their own expense.
Or has the tiler put too much glue behind the tiles?
Generally measure depth of tap set back from the 'supposed' face of finished tile.
This can vary on how much glue is used.
Someone will work pit who is to blame
We fitted the plasterboard and tiles ourselves. I didn't use too much adhesive. The plumber actually admitted that he had set the valve block too far back. He has given us a refund, minus £10 that he said he used for parts, but that is nothing cost wise in comparison to what I may need to pay to get this sorted.
You have 2 options.
1/ contact supplier / manufacturer of taps and see if extensions are available...or
2/ contact plumber to rectify at their expense or get their insurance details to pay for all works required in getting the taps set to required depth.
Opening up shower walls is an expensive exercise.
Removing tiles, resetting tap depth, plastering walls, waterproofing and re-tiling and so on.
Hopefully the Plumber has insurance, because if they don't, it's probably not worth chasing them and you'll end up footing the expense.
A refund on a stuff up doesn't negate liability...particularly in your situation.
There's around 30 hours of work involved for all works necessary to repair that stuff up.
I don’t know the particulars of that shower but if the handles fit onto those brass bushes can’t they just be packed forwards with a spacer or washers?
In extremis get a local fabricator or a hobbyist to machine you up new brass bushes of extended length. I have done this myself on a friends lathe and my skill level is low.
We've already tried to pack it out with spacers but for some reason there's a mechanism on the middle valve handle that prevents you from doing this. Thankyou all very much for your input. I think I need to get on with the inevitable and break back into the wall. We contacted the manufacturer to see if they do extention kits, which they do not, so I don't have many options.
stud wall ? Can’t you undo the fixings and pull the shower body forward ?
Also you look kinda screwed on the handheld I’m guessing that’s the valve in the wall ?
Just sitting here thinking if I could fox this without opening walls up.
I think I could, would be difficult and not 100% certain to work, but I’d spend an hour or two trying.
The valved outlet… potentially you could get a 90 outlet with a 1/2” female connection. You could then wind it on to the valve. The valve/hole would be cover by a chrome echelon.
This obviously depends on being able to turn valve on, if it’s off and finding the correct parts. A quick google shows there are female connection outlets.
Second option would be to undo the valve, pull it out and fit a female iron on to the nut/olive in the wall. Could be possible, potentially using screwdrivers/steel rod inserted through tile hole, down the side of valve/new female iron to hold the nut while undoing/doing up. Might need to enlarge the tile hole a bit, not difficult with a 6mm diamond angle grinder bit to slowly enlarge.
Option 2.5, same as above, get valve out and using a soldering coupling, extend pipe out of tiles and fit suitable outlet. Should be enough pipe to solder to even with nut/olive left in wall. If not, use 15mm pipe, a coupling, then small bit of pipe (2mm longer than slip of above coupling, then slip coupling. Slide the above into hole and slip over pipe in wall. Once on, hit with hammer and hope the olive moves back, until enough room to solder.
The problem with the handles, doesn’t seem to difficult to resolve if you’ve got the tools/ability or are willing to pay. The below would likely be a lot cheaper than opening the walls.
Instead of trying to pack the brass spindle adapter, just extend it.
Either some sort of fitting you could screw on to the end of existing brass (using exsisting/new longer screw). This would be more difficult.
Or add an extension (same diameter as where the handle set screw tightens on existing brass) to the existing brass. This should be hollow to allow the screw to be done up. This extension should be silver soldered on to existing brass.
Could make the extension out of something like a brass 1/2” nipple. I would as I don’t have brass stock.
If you found a brass machine shop, they’d have all 3 done in an hour. My friend makes brass radiator covers etc and could easily do this.
Here’s something similar I made using my mates lathe/milling machine as the apprentice lost one of the originals!
I’m with Tim, and it’s easier than he thinks as there is no issue with the outlet connection!
It’s just the handles.
Like I said in post #5, this is a relatively trivial matter to fix - for someone with a metal lathe.
I would definitely go down this route rather than open up the wall - it will be far cheaper.
Reply to Concealed shower advive please. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I recently had a plumber come over to look at a badly leaking shower head. As best I can recall, he described the problem as a crack in the bridge...
Hi all, I have an issue with our shower's hot water. The shower is operated using two separate taps for cold and hot water. When the hot water tap...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
Hi im just starting new shower in our new extension. Its a concealed thermostatic mixer from victorian plumb, no instructions. Im putting the...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
