Discuss Conex iso valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So the conex valve could give me issues?
Not to say they would but if you have an oppertunity to change them now then I personally would....regards Turnpin:biggrin:So the conex valve could give me issues?
another vote for level valves if you have the space
and find the full bore iso valves better (havent had a problem with one leaking yet)
Thanks are boundary stop taps usualu ok to turn off and on is an old one wont turn by hand but a stop tap key will likely do it
I have actually run down my stock of standard ballo's and only using full-bore now; bit stiff to begin with but have soooooo much more confidence in them!
Need a good screwdriver and work them a bit
They are very tight, but I guess that proves they are same as lever valves, with the ptfe seal nice and tight.
from new with no water i find they are but with water there fine (bit of lubrication )
Slippy when wet.
Weird isn't it that ptfe is supposed to have the least friction of any material except 2 blocks of ice together, yet it needs water to lube it?
everything is better with lube
Lol! Open forum, so my lips are sealed, if you pardon the expression. :smile:
trust you to think that get your mind out the gutters
Are conex iso valves usually pretty reliable? I.e they won't leak from the slotted section on the valve years later if turned off and on for maintaince work.
Like with most things you've got a 50/50 chance cheap valves are more likely to leak in the future but doesn't mean they will
Quality valves are a lot less likely to leak but that doesn't mean they wont
as for the boundary stop tap, if It leaks after turning it on or off call your local water board and they will have to come fix or replace
Reply to Conex iso valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
