Discuss Conex Lockshield Valve Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
philr
I've got a problem with a Conex Lockshield Valve - seems it's fairly old (+30 yrs) - and it may just be seized up, but before I do anythnig more drastic I thought I would ask this forum.
The valve consists of the valve body, a metal cover, and a large screw. The screw top reads "Remove to reset" & "Conex Pat App". The spindle for the valve is very slightly tapered, and has a single flat on one side - and because it's in a tight corner, it's impossible to get any kind of grip on to the spindle to rotate it.
However, on the basis of a previous thread (Odd lockshield valves - can anyone help me adjust them?) there may be some other way of adjusting this valve - I've tried doing what was suggested by tightening the screw head, but that doesn't seem to want to move anything.
I only want to close the valve in order to remove the radiator for decorating, so to have to drain a large CH system just for that seems overkill.
Any suggestions as to how I might proceed?
you could get tank bungs and change the valve under vacuum no need to drain down then
Or close opposite valve, freeze below valve and change it live.
Reply to Conex Lockshield Valve Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
