Dannyg2325
Hi all,I'm hoping someone can help shed some light on this matter.I'm building a bungalow to passive standards, but the 3 plumbers that I have obtained quotes from are insisting on full oil fired central heating with rads everywhere.This is far from what I want so have gone back to them with a plan that fits in with all the money I've spent building a house for the next generation and don't want to take a step backwards.My plan is to have a 1000L accumulator tank with solar coil, a 21kw stove directly linked to the tank.There will be a central heating circuit on this that will supply 3 towel warmer rads in the bathrooms, this should also act as a heat dump should the buffer tank get too hot. it will also feed a 350L DHW tank that is also fitted with a solar coil and 2x 3kw immersion heaters.Here's we're the "problems" begin, the system has to be pumped as the buffer tank is on the same level as the stove. I have seen/read about this being doing to a very safe standard and working very well, but the 3 plumbers insist it won't work.I know their issue is not being able to gravity feed the system. But I just can't do that because of the ceilings being vaulted.So to sum up, I want a WBS linked to a large buffer tank, heating circuit run to 3no bathrooms, DHW linked to buffer tank. Solar to feed DHW first (then buffer tank when DHW is hot enough) would like the system to mains pressure.I could type all night about how I would like it to work but I won't.lol. I think my next step is to draft in a heating engineer, but in the mean time I'm open suggestions.If I've missed any info to help just ask
