Discuss Confused!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rychus
I'm hoping someone can help. I've got an open vented y plan central heating and water system with tanks, pumps, valves etc. My previous boiler only had a flow and return. It packed up a few days ago so I purchased a cheap iqe system boiler to replace it as I really wanted a Combi but that's not a job I want to do just before Christmas. This iqe boiler has a dhw flow and return and a central heating flow and return. Now for the system I have I was told I can cap off the dhw f&r and use just the central heating f&r. I have done this but the boiler is faulting as the water pressure is too low. Should I have used the dhw f&r or is that not possible?? Please help need some heat for crimbo lol
Oh dear!
So much wrong here! Which, as you have illegally installed a boiler to a system that has not been altered to suit.
Apart from the obvious heating pipework issues.
How did you calculate your gas pipe size?
How did you gas rate?
How did you do a flue gas check?
How did you register it with local authority and gas safe.
Good luck with getting a competent gsr in to look at it.
I look forward to reading about you in RGE.
Reply to Confused!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
