Discuss Connecting new toilet to waste in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the branch) and plan to place it the opposite end of the room. I was pretty lucky to find a 110mm sewer waste pipe below the old sink which is the new toilet location so need to connect the toilet up to this now.
There's no existing above ground pipework there as you can see in the attached (old) image, the toilet will be centered in the 600mm cabinet outline drawn on the ground. The toilet is a back to wall version so the pan connector needs to go straight out from the back of the toilet, 90 degree bend left and then down into the sewer waste.
The plumber said there's no issue in doing it when he was out months back and to call him when I want it done but I thought I'd see how easy a DIY job it is first, given I've done most of the bathroom so far. I'd rather avoid flexi waste pipes if possible, I see them used quite frequently but I can't really see how the accordion design is a good idea long term - even if easier?
From my understanding I'll need this pipework (sorry for the general screwfix names)
  • MCALPINE PUSH-FIT SINGLE SOCKET DRAIN CONNECTOR BLACK 110MM
  • MCALPINE RIGID STRAIGHT WC CONNECTOR WHITE 260MM - out the back of the embedded pan connector.
  • Then some form of 90 degree bends to connect these - this is what I'm unsure of exactly.
Advice appreciated, feel free to say if it's a deceivingly difficult job and I'll contact the plumber but I'm fairly confident once I know which connectors are required.
I managed to get a setup I was happy with in the end which was a drain connector, 90 bend, 45 bend, straight pipe into a 12 degree pan connector. I was very close to a Flexi though!
Well persevered, it is always worth the extra effort to plumb the pan with rigid waste.
It’s a good idea to restrain the pipework in some way to stop it moving as you push the pan back, this only needs to be a block of wood or similar.
However if access in the unit is good then this may not be necessary , it’s more for when you’ve made a tiled box yourself.
Reply to Connecting new toilet to waste in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet...
Hi all, I have an old toilet on the top floor (to be removed) which empties into an outdoor vertical SVP and into the ground. The pipe is...
I’d like to replace the toilet in my house with a back to wall one. The plan is to build a panel on stud work to conceal the cistern and then use...
2K
I'm a DIYer and have a problematic toilet setup to fix: The waste pipe was installed too high for waste to flow out from a standard toilet...
