Discuss Connecting to cast iron tee in the USA area at PlumbersForums.net
Matt0029
What's the best way of connecting 110mm plastic to a cast iron tee after removing the lead? Is it to just clear out the flange on the tee insert the 110mm pvc. Then rope and plumbers mate or silicone?
Depends on the internal size sometimes you can get a black drain connector in
Thanks yes I have used the drain connectors before to go in to cast iron pipe but never a cast iron flange/fitting. I will have a look. Q
normal way would rope packed in and cemented over/ infill
I had this problem a few years ago. I managed to find a fitting that worked like a pan connector. Bellows end went down inside old cast iron stump. Then new plastic 110 slotted into the silicone rubber-ring sealed end. I laid silicone sealant around the plastic end but.... it didn’t take to the flexible seal too well. Was worried I might get some smell but 4 yrs on and daily use I have no problems. If yr interested I’ll search the part out but imo it was basically the same as a straight pan connector only black plastic
[automerge]1595784837[/automerge]
https://www.NoLinkingToThis/p/mcalp...Vi7HtCh00Gw7FEAQYAiABEgL3tPD_BwE&gclsrc=aw.ds
Reply to Connecting to cast iron tee in the USA area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
