Discuss connections to bidet using Geberit frame in the USA area at PlumbersForums.net
Struggling to make the connection to the bidet. The bidet has a flexible hose connection with a 15mm female end to attach to the Geberit frame. The water take off male connection on the frame looks to be 12mm. Is there a coupler required?
  • Datasheet.pdf
Reply to connections to bidet using Geberit frame in the USA area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
