Discuss Connectors for potable water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
A novice question.
I am trying to replace the kitchen tap. The current tap is soldered to copper pipes under the sink. I will need to cut those but I don't want to do any soldering (don't have the tools/knowledg) so I was looking at other types of connectors.
I found the following push fit connector:
https://www.NoLinkingToThis/p/tectite-sprint-brass-push-fit-adapting-male-coupler-15mm-x/94310
It is Manufactured from Copper and DZR Brass.
1- Is it suitable for drinking water?
2- Can pressure fit handle mains pressure.
Many thanks.
You will probably find the copper tails are screwed into the tap not soldered , you will be able to get a flexi hose to help you install the new tap , most come with flexis these days .
https://www.NoLinkingToThis/p/hose-15mm-x-m10mm-x-300mm-2-pack/66361
If the new taps don't come with suitable hoses then just buy a new pair such as these with a 15mm compression joint to connect to the copper pipes under the old taps once you cut & remove them. (the ones in the link don't seem to be WRAS approved- see below)
Please make sure that both the new taps & the hoses (or any fittings used) are WRAS approved otherwise you could fall foul of the Water Supply (water fittings) Regulations 1999.
So, Yes it is suitable for drinking water and Yes, they can handle mains pressure. Hope that answers your question.
Flexi's on the other hand are common and can get you out of a lot of problems with misaligned pipework but be careful if you have a low pressure hot supply as the bore on the flexi's can be very small as they are better suited to high pressure supplies, in that instance, you can't beat a full flow copper tap tail. (Or in my opinion a separate hot and cold tap!)
Reply to Connectors for potable water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use...
Hi Can anyone advise how the copper push fit connectors work? Is it a matter of just pushing in the pipe until it goes in as far as it can and...
1K
R
Hi there, Please excuse my lack of knowledge on this, my plumbing knowledge is very limited. I have a cold water feed going into cistern with...
Hi everyone - I have an old outside tap with male thread but struggling to find a right hosepipe connection after the other one broke. The top of...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
