Discuss Connectors for potable water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
A novice question.
I am trying to replace the kitchen tap. The current tap is soldered to copper pipes under the sink. I will need to cut those but I don't want to do any soldering (don't have the tools/knowledg) so I was looking at other types of connectors.
I found the following push fit connector:
https://www.NoLinkingToThis/p/tectite-sprint-brass-push-fit-adapting-male-coupler-15mm-x/94310
It is Manufactured from Copper and DZR Brass.
1- Is it suitable for drinking water?
2- Can pressure fit handle mains pressure.
Many thanks.
https://www.NoLinkingToThis/p/hose-15mm-x-m10mm-x-300mm-2-pack/66361
If the new taps don't come with suitable hoses then just buy a new pair such as these with a 15mm compression joint to connect to the copper pipes under the old taps once you cut & remove them. (the ones in the link don't seem to be WRAS approved- see below)
Please make sure that both the new taps & the hoses (or any fittings used) are WRAS approved otherwise you could fall foul of the Water Supply (water fittings) Regulations 1999.
So, Yes it is suitable for drinking water and Yes, they can handle mains pressure. Hope that answers your question.
Flexi's on the other hand are common and can get you out of a lot of problems with misaligned pipework but be careful if you have a low pressure hot supply as the bore on the flexi's can be very small as they are better suited to high pressure supplies, in that instance, you can't beat a full flow copper tap tail. (Or in my opinion a separate hot and cold tap!)
Reply to Connectors for potable water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
