Discuss Constant Airlocks in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Plamber
Hello all.
The system is an open vented system with the cold water tank 5" above the cylinder in a small cupboard so there is no way of removing them (must have been built in). it is heated by immersion heater.
The thing is, its airlocking every couple of days, the woman said its been like that for 8 years and has only now tried to get it sorted.
What i have tried so far is emptying both tank and cylender and filling up from washing machine valves, from bath taps, WHB taps and kitchen taps. getting everything working for a few days then the pressure on the hot water drops to very slow. the kitchen and bathroom are on different sides of the flat and all the pipework seems undamaged (no kinks,dents). I even had another and very experienced plumber with me today and he was confused with it. his suggestion was some kind of flange, something ive never fitted or used before.
ADVICE PLEASE.
thanks in advance
I have also increased the hight of the vent pipe as much as possible.
Dose the hot water distrabution pipe rise slightly when it leaves the cylinder?
Is there a pump on the system for a shower or to increase flow?
no, its a very basic system. flat doesnt even have a shower.
Hello Plamber,
I've been following this post but I haven't got any useful to contribute but I don't understand your last post.
I don't understand why the customer wants something doing now after such a long time, has it got worse for the customer!
Is it possible (I really don't know) that there is a dodgy gate valve somewhere creating a problem or a tap, as I'm typing this I'm thinking 'you'd see a leak though"
She lives in a rented flat from a housing association. the previous owners ignored her when she mentioned it. but the housing association i work with have now purchased the whole housing scheme and pride themselves on prompt repairs.
The only thing i can currently think of is fitting an unvented cylinder. but that seems pretty excessive. is there some kind of flange or fitting i dont know about that i could fit to the vent pipe??
I can't think of anything, hopefully, someone else will. Have you spoken to your local merchant about fittings etc. I find them extremley helpful.
not sure really does the cwsc fill up quickly enough ? no blockage? maybe when filling the bath its emptying quicker than filling the cylinder,
an unvented ? why not a combi ?
Reply to Constant Airlocks in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
