Discuss Constantly losing hot water pressure from Direct Vented Cylinder in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Which taps are causing the issue? Seperate bath basin taps should be fine as long as the pipework has been done right. The kitchen tap is the tricky one but its certainly possible to still get a good enough flow rate out of it.
My plumber (new guy) is going to strip out the pump tomorrow and restore the status quo, will re-assess after that & hope it doesn't stop completely !, thanks for the guidance
Yeah, not the best is it, I have a couple of mates in the block & there's was never as bad as mine, must be something specific to me I guess
How old are your taps ?
Reply to Constantly losing hot water pressure from Direct Vented Cylinder in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
