- Messages
- 710
i serviced and did a landlord safety certificate today and it did not have any earth continuity was not visible i know it has to be a minimum of 600mm. the customer wants us to get it earthed.
we will get a sparky to take a earth connection from gas pipe to the consumer unit.
the problem is the only way possible would be to take around the parameter of the property would be under the harling stone before it meets the brick work then drill a hole to the consumer unit but i thought about another method but it will be down to the electricians decision. how about an earth rod that you can purchase from plumb fix? would this be a suitable for gas safe pipe work?
i just want to know for future knowledge. thank you
