Discuss ContractorForum: Grouting problems - help please?: Hi, would appreciate some advice o in the Plumbing Jobs | The Job-board area at PlumbersForums.net
- Status
Administrator
Staff member
Admin
- Status
Reply to ContractorForum: Grouting problems - help please?: Hi, would appreciate some advice o in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump.
I see a boiler pump menu for either 70% or 100%, so, is the pump set at either one of two fixed speed percentages or does the pump actually vary speed, (modulate)...
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking?
This originally happened about 12 months ago and has happened 3-4 times since.
It’s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
My current hot water system needs to be replaced.
Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't rip me off?
An office guy recommended me to apply for government rebates and get it installed through timetosave.com.au.
How reliable is this...
Hi all
Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my toilet a good few times nothing is going to the sewer so don't know is there a blockage or what way it works many thanks and advice would be grateful
Hi all I'm hoping someone can shine a light on this for me
Since our stop tap on the pavement has now been filled with sand for whatever reason, we are relying on our property fitted stopcock (this is outside on our garage wall)
Unfortunately turning this to the closed position only reduces...
