Discuss conversion to hive heating on combi boiler in the Central Heating Forum area at PlumbersForums.net
hi,i need slight help with adding hive system.
Odd they’ve used the right hand L port. You have posted single channel wiring diagram, but your product is the dual channel. You can still get it to work, but will have a non functioning hot water side, do you want help still, or are you returning it for a single channel?
Single Chanel is as below
L to L
N to N
Earth to Earth
A old to new 1
B old to new 3
Reply to conversion to hive heating on combi boiler in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
