Discuss Convert fluidmaster flush valve for use with euro flush pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Any ideas? They have a 1.5" outlet, too small for the Euro flush pipes. They come with a 1.5" to 2" adaptor so can fit in the cistern fine.
You can use any drop valve with a 2" outlet but never found one I like half as much as the Fluidmaster.
And as far as I'm aware you can't use a normal flush pipe on a pan designed to take a euro flush pipe.
I suppose that would be another solution. A pan bung sized or adapted to have an ID for a standard flush pipe but an OD to fit a euro pan.
They do them, I've been fitting a hideaway fluidmaster cistern and the kit comes with a flush pipe big end and small end.
I'll take a pic tomorrow.
What feedback have you had on the lever valves watertight, you know the little lever instead of the button.
I think they feel a bit nasty but I haven't fitted it yet.
The geberit flush pipes are a right pain in the arse
Is that not a pneumatic flushing one?
Not fitted the lever ones, someone on here said the handle was tiny and naff and that put me off.
No just the normal cable type, I think its the 550mm cable though, didnt have time to take pic today.
Well I'd love to know where you can get them? Every cable one I can find online (including 550mm) has a 1.5" cradle.
damn forgot the take pic again...so much to do in bathrooms didn't finish till 8pm.
Reply to Convert fluidmaster flush valve for use with euro flush pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
