Discuss Copper pipe slightly too short in the USA area at PlumbersForums.net
I have replaced some parts in my toilet cistern including the rubber seal between the cistern and the toilet. Unfortunately the replacement is thicker than the previous one and as a result the copper water pipe doesn’t match with the cistern inlet by a few mm. Any thoughts on how to resolve this problem?
1/2 - 15mm female iron should sort this and either a washer or ptfe on the plastic threads
Thanks for the suggestions. Currently the isolation valve and the plastic inlet are both threaded. I thought a compression fitting was for smooth pipework?
[automerge]1596322405[/automerge]
So I need one of these? Compression Adapting Female Coupler 15mm x ½ - https://www.NoLinkingToThis/p/compression-adapting-female-coupler-15mm-x/93992
Correct thread the internal threaded part onto the valve you might have to undo the inlet valve so you can raise it to get it on and thread it all the way down until it stops
then try it for length if you need more than a few mm you will need ptfe if not your fine with just a 1/2 washer
https://www.NoLinkingToThis/p/arctic-products-shower-hose-washers-5-pack/3841j
Be careful not to cross thread the plastic when you start
I got a 15mm to 1/2 inch coupler. Unfortunately it doesn't fit as the diameter of the isolation value connector is 13.85mm.
I've measured the pipe before the existing isolation value and it's 15mm. Phew. So I think I'll replace the isolation value as well and hopefully that will resolve the problems.
I misidentified the connection size. The top of the valve is 0.5 inch and the cistern fitting is 0.5 inch so I need a tap extension as some have suggested. Unfortunately I didn’t understand the difference so went down the wrong path (or should that be pipe). I have bought several of them so can link them together if the gap is too big for just one.
[automerge]1596371971[/automerge]
Not so sure a tap extension will be long enough there.
What would you do then? Use several tap extensions together? That's my plan.
doesn’t fit on the Id of the threaded end? As it should fit
Reply to Copper pipe slightly too short in the USA area at PlumbersForums.net
