Discuss CP12 on a gas hob in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Oh and I've yet to see a fsd on a hob too, maybe I'm missing something?
obviously gas rating it will tell you if its using the right amount of gas, but normally you can tell when the thing starts using too much gas by looking at the flame picture, it may only take 2 minutes to pull out a oven but you need a shower after :/
Yeah but I've been to leaks on an orange LPG hose on natural gas that had fallen off with no jubilee that was checked 3 months earlier.
what does that mean ? how about this, i did a cp12 and a month later the gas pipe under the floor was leaking, do i rip up floors everytime i do a cp12, no! so why should i start pulling ovens apart ? not to say a dont
I bet you that gas rate was through the roof!! :rofl: (tongue in cheek)
I've been to several explosion incidents, CO poisonings and house fires with the HSE, but who's braggin!!! Only ever gas rated the grille of an oven at a CO incident! Flame picture was as floppy as a grannies mammary gland .. lol
im i right in thinking the only time a hob gives of co is when someones been messing with the jets and fat is all over the shop and you either get flame lift off or no flames at all due to lift off and fat..
if its nice and blue i dont see any point
Flue Gas Analyser??
Always confuses me why a consumer would need a means of isolation for a gas hob !
And dont forget most fancy modern kitchen designers put a gas hob over a drawer. Most MI require a fireproof board fitting beneath the hob to protect contents of the drawer/ customers hands.
personally i think you would want to read the data badge on the appliance to check its heat input, it is correct for gas type, and ce marked. then you can gas rate it, simples. Most u gauge hoses dont fit over nipples very well so working pressure can be unreliable sometimes.
means of isolation is for engineer to perform work on appliance not for customer to turn off.
Reply to CP12 on a gas hob in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all gas engineers. While doing landlord’s gas safety , if gas hob do not have data badge or manual . How can we test it for safe to use ??
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It...
Hello, Can anybody tell me what the engineer is required to check in the process of doing an annual gas/boiler safety check? Is there a specific...
3K
Aquarius
A
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
