Discuss cutting yourself on a burr in the USA area at PlumbersForums.net
what should you do if you cut yourself on a burr while cutting copper pipe? Why?
Expanded question:
What might the negative effects of having a cut finger in a working environment be to yourself, other workers, the premises, and your customer? How might you mitigate these negative effects?
Well I'd probably not log on to a plumbing forum to ask for advice before stopping the bleeding. IIRC, you need to apply pressure to stop the bleeding as your first move.
Depends a bit how bad the cut is. Are we talking 'ouch' or 'WTF, where's all that blood coming from and why is my finger flapping around like that?'
Wrap the cut in duct tape or electrical tape.
Not too tight, just enough to close the skin flap and reduce the bleeding.
( the tape won't stick to the skin because of the blood )
Keep on working.
That's what I did when doing a job for a customer 150 km away from anywhere that could help me.
It probably needed stitches, but the tape got me through the next 2 days to finish the job.
Keep on working.
But don't put the adhesive directly on the cut (put the first section on inside out), so I am told anyway.
Reply to cutting yourself on a burr in the USA area at PlumbersForums.net
I know no one really does. But technically why should we use bonding clamps when we cut a section of gas or water pipes out? Thanks.
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by...
Hi I need to this cast iron pipe back as my new back to wall toilet won’t fit otherwise. Cutting it back i am going to lose the collar. So what...
Easy if you're a plumber I guess, but if you have no plumbing knowledge? Its a Bosch, nearly ten years old I think, its door won't shut, so it...
We have an old gas pipe in the understairs cupboard. The previous occupants had the gas meter moved, but this old pipe remained. This pipe goes...
