Discuss Cylinder single stat to a duel cylinder stat ?.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hi, I've replaced a gravity cylinder to a unvented cylinder. I'm about to wire the duel thermostat for the cylinder. I have a live, netural and earth from the old cylinder stat. I know the live is for com. But where does the switch wire go?
What uv cylinder you got as there's normally a wiring diagram in the book
And direct or indirect
Indirect cylinder. I've looked at the instructions and it says com live, loop wire connected too 2 -c the switch wire to 2.
It's a Joul cylinder.
If I connected it wrong the zone valve won't open?
Also I'm another question. It's for a Worcester vertical flue going through a loft but it passes near a joist about 25mm. I've read the Worcester instruction nothing about the distances for combustible materials so I looked at
BS5440: Part 1 and IGE "Gas Installations in Timber Frame Buildings” And couldn't find any thing on this either. Any advise?
Any chance you could post a pic of the instructions Saves me going to hunt for them
And new condensing boilers are fine just need an air gap
They won't normally be LN+E!
There will be a switched live from a programmer to - as you say - Common normally or No1 (read MFI's)
You need to test which is the terminal that closes on demand (to live) That will be your switched live back.
You need to test what the wires are!
What system?
S plan, Y plan etc?
so c is your switch live from your prog
2 is the call from your first stat
so link 2 to c of other stat
and then from your second stat 2 link that to your port valve open (eghh brown wire)
I thought com was for live wire? But it's for switch wire? Is this always the case for com? Ta
Say I have removed a old cylinder stat from a gravity cylinder. There will be 3 wires but they might not be identified in what they should be. But there should be markings on the stat so I will copy that on to the duel stat.
No, not always, just in this case the live to the cylinder stat will normally be a switched live from a programmer.
It depends. I always test everything when wiring. Especially control wiring as people use all sort of colours for all sorts of things.
If you took the earth wire from the case of the old stat (earth terminal), then it would have been used as an earth.
One of the others will be live from the prog and the other would probably have gone to Boiler?
That SL should now go to Brown on MV.
I want to wire this to a duel thermostat for a joul unvented cylinder indirect s plan.
Brown to common left stat / no 1 stat
Blue to right stat / no 2 stat
Link port 2 on first stat to common on second
Hope this helps
Thanks. confussed about the link ?
Cheers
To join the two stats check my pic out
S/l out of the first stat into the common of the other
Thanks mate it worked. Once the cylinder got to temperature the zone valve closed the when it called it opened. Great I did swap over last night and all day today finished and ÂŁ400 better off!
thats great side jobby?
Yeah I great homer. I'm doing a few and getting my own customers before I set up on my own.. the reason to why I asked about the wiring is the last cylinder I did I wired it the way you said to do it. But they said i wired up wrong, which I can't see how I did. So today I did the same and tested it and it worked. I think there at it, but it was through my work company.
dont see how you could wire it wrong only backwards but it would still work
its light switches (on or off)
I agree too. I think the customers aren't pleased with my work company so maybe this is there way trying not to pay there bill. Are you self employed?
If so for how?
No I'm not and don't want to be tbh
With all your experience you would work less and earn more..
True but then again I don't have to do paperwork etc and can switch off at nights etc
Reply to Cylinder single stat to a duel cylinder stat ?.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
