Discuss Dark marks from radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Anyone have any ideas why I am getting dark marks on my walls radiating upwards for about 350mm in line with the radiator mounting brackets and is there a cure.
Any chance of a pic
Sounds like heat staining
Hope this helps
In short it's dirt and it's rising in the heat and staining on the wall
Very common
And tbh not much you can do
Vacc and a duster to clear out behind the radiator.
You could fit a shelf a few inches above the radiator to deflect the convected heat away from the wall a little, also its worth getting a long handled bottle bush to remove dust build up between the convection fins and improve the heat output.
As Shaun said, dust normally. It is common. In houses where people use candles or smoke that's another common cause of stainng.
The air circulates quite quickly around radiators due to their design.
Seen so called Ion air purifiers cause it .
( No longer have a CRT TV to attract all the fine black stuff )
-- Also noticeable with modern decoration Laminate, no carpet / rug / curtains for it to gather on !--
Have carpets down in all rooms, regular vacuuming
Probably just leaves cleaning radiator fins .
(look with a torch..)
( you will find cobwebs - so get the "Right" person for the job !)
..If there ever was a coal /coke fire - it's not always the smokers..
Just ordered a cleaning brush so will give them an extra special clean when I get it
Reply to Dark marks from radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
