Discuss Dew point on condensing boilers in the USA area at PlumbersForums.net
Can anyone tell me the dew points in kerosene and natural gas condensing boilers please.cant find answer online
How accurately do you need the answer? From memory, for natural gas with 10% excess air (for maximum efficiency) the dew point is about 58°C, for oil it's about 49°C.
Don't forget that if you need a boiler to condense a useful fraction of the water vapour in the flue gas you need the return temperature to be significantly (say 5°C or more) lower than the theoretical dew-point.
The big easily got gain with a HE boiler vs a SE boiler is the extra sensible heat extracted from the flue gases due to another Hx installed (called a economiser on steam boilers) which reduces the flue gases by ~ 150C leading to a 7% to 10% gain in efficiency, any condensing effect is a added bonus, fairly easily attained with outside temperature compensation.
Reply to Dew point on condensing boilers in the USA area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
