Discuss Digistat 1 Room Thermostat Problem in the Central Heating Forum area at PlumbersForums.net
So my Digistat 1 room thermostat is giving problems. Battery warning light on even with new batteries and I suspect I need to replace it - but with what?
Short term it now wont switch on the heating so how do I bypass the thermostat and set the heating to on. There are three contacts
Common
Heating Satisfied
Call for Heat
Looks like you connect
Common to Call for Heat to turn heating on and
Common to Heating satisfied to turn heating off
I can make a little bridging connection easily enough so does that sound right?
Reply to Digistat 1 Room Thermostat Problem in the Central Heating Forum area at PlumbersForums.net
