Discuss discharge from pressure valve ,pipework from valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
yes part of nvq 3...why...!!!this in relation to your unvented thread???
do you have your unvented ticket??
G3 Regs http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADG_1992.pdf
what i'm trying to get at on this thread is that a combi i went to had it's discharge pipework discharging into waste pipe work what terminated to outside picking up the condensate on the way,the mi is a bit vague and does not explain it well enough so the punter can understand, so i was wanting a bit umphh to approach punter with bs numbers, regs etc,yes part of nvq 3...why...!!!
Reply to discharge from pressure valve ,pipework from valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
