Discuss Dishwasher and washing machine leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Cristina
Hi all, I have a problem with blockage (I think)
First, the dishwasher didn't drain, so I did an empty run with some vinegar, and that seemed to clear it. All was fine for a while, once or twice I had a bit of an overflowing from the sink drain, more a gargling like noise, but that was all. Today I found water under the dishwasher after running it, and then I was running the washing machine and I found a leak under the sink where the waste pipe connect to the sink drain pipe.
How can I attempt to unblock the blockage, if it is a blockage, before calling a plumber?
Cris
You could try dismantling the trap to see if there's anything blocking it, if it's clear then you've likely got a blockage further down which if you don't own a 'snake' could be difficult to clear. Whatever you do; don't use a drain cleaner - if you do, tell the plumber you did to avoid him/her getting burned.
Thank you. I'll get a 'snake' and try that first. I won't use the drain cleaner.
Please let us know how you get on, it may help others in similar situations in the future.
Reply to Dishwasher and washing machine leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
